February 21, 2019, 12:09 |
CFX - Domain error
Rakshit
Rep Power: 9 |
Hi All
I tried to model the heat source (radiator) inside the room, I managed to model and meshing it, now the problem is applying the boundary condition as I am facing the problem (I have attached the error in the below presentation) problem description I want heat source to produce specified heat (say 20 Watts) and I want to see how much time the air in the room will take to reach target temperature (say25 degC) Can you please give me some tips over it on how to consider Thanks in Advance |
February 21, 2019, 13:06 |
Rep Power: 33 |
Check the list of Location used for the boundary Heat Source/Heat Capacity.
It seems you have selected the same mesh region twice for two different boundaries. From the pictures, it is difficult to see if the mesh for Room also contain the volume for Heat Source (hope not) |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
