Heat transfer
Old   February 11, 2019, 05:00
Default Heat transfer
Pedro Oliveira
oliveira1820 is on a distinguished road
I am modelling the water inside a domain, heated by different energy sources.
I have designed geometric subdomains which will be used as reference to define energy sources inside those subdomains.
The problem is that, in CFX-Pre, the software assumes that there is a wall between the water domain and the energy sources subdmains, thus, resulting in the separation of the water inside the subdomains and the remaining domain.
How can I define the energy sources geometrically and tell the software that water occupies equally all the domain?
oliveira1820 is offline   Reply With Quote
Old   February 11, 2019, 06:01
When you define the domain select both the main fluid region and the heat source regions. Then define a subdomain with just the heat source regions in it.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 12, 2019, 04:05
Pedro Oliveira
I did exactly that but the software automatically defines a wall between the energy source domain and the remaining domain. (and I canīt delete it)
I want that water fills the entire domain equally, even on the subdomains location. The subdmains should only work as a geometric reference to the enerngy sources.
Old   February 12, 2019, 11:33
monkey1 is on a distinguished road
What do you mean with "geometric subdomain"?
Two separate meshes?
If yes then you will have to define interfaces between the meshes and there you can select, that they should be "open"
If you have 2 (or more) meshes glued together without interfaces, then CFX-Pre will automatically set the contact surfaces as "wall"...
monkey1 is offline   Reply With Quote
Old   February 12, 2019, 14:28
Pedro Oliveira
I mean subdomais respective to the geometric cylinders Iīve designed, that correspond to differnet meshes yeah.
So, defining the interface as opening it is the same as if there was no interface at all, for heat, mass and momentum transfer?
Heat transfer coefficient in regenerator gartz89 FLUENT 0 May 26, 2018 02:23
Flow around heatsink with heat transfer S Mughal FLUENT 0 April 13, 2018 14:06
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Question about heat transfer simulation Anna Tian Main CFD Forum 0 January 25, 2013 19:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
