July 20, 2005, 15:37 |
Periodic BC on Inlet and Outlet of a Duct
Hi
I was wondering if anyone has experience with applying periodic boundary conditions to the inlet and outlet of a duct, ie making the pipe infinitely long to obtain fully developed flow. I am using TASCflow v.2.12 and it does not like to apply the periodic condition as well as the inlet or outlet condition. Is there a method to get around this problem, possibly to apply a pressure gradient over the duct or define the mass flow rate not directly on the inlet or outlet? Thanks in advance Steve |
July 21, 2005, 09:27 |
Re: Periodic BC on Inlet and Outlet of a Duct
Create a subdomain ---> momentum source
Momentum source is like a (DeltaP/L). Good luck. Ask me if you are in trouble. Bye |
August 8, 2005, 13:03 |
Hi, I have a problem in implementation of periodic boundary condition in a duct for a turbulent flow. The way I apply it is: copying outlet velocity multiplying by a factor (for correcting mass) to the inlet and copying pressure at 65% of length of the domain -(Pave at this cross section=65% of domain) to the outlet. I don't know if it is correct.
I know there is another popular method : using the (dp/L=-4*Tauw/Dh) as a momentum source in streamwise direction and copying velocity and pressure to the inlet or outlet. But I can't understand this method. I really appreciate if someone can help me. Thanks in advance, A.W. |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
Inlet shapes for modelling a fan in an inlet duct | buzzybee | CFX | 10 | June 11, 2009 21:15 |
Duct Flow with 90 degree inlet and outlet | k | FLUENT | 3 | August 19, 2007 15:30 |
outlet = inlet in a periodic geometry | Stephane bone | Siemens | 3 | January 20, 2005 04:26 |
Periodic boundaries at inlet and outlet? | Michael Bo | CFX | 4 | March 15, 2002 03:24 |
