Binary Diffusion Coefficient
Old   July 19, 2005, 10:56
Default Binary Diffusion Coefficient
Frank
Hi everyone!
Does anybody has experience in setting binary diffusion coefficient for Kinematic Diffusivity in CFX 5.7.1?
I read about USEDIF fortran subroutine but is not supported on this release of CFX (it's for CFX4 only).
Thanks in advance for any suggestion.
Old   July 22, 2005, 11:01
Default Re: Binary Diffusion Coefficient
Jeff
Constant diffusivity is set under the fluid properties. If you want a variable diffusivity, set it to a CEL variable, and calculate the variable value in CEL as a function of temperature, etc.
Jeff
Old   July 26, 2005, 05:04
Frank
Thank you Jeff!
Can you also suggest a source (or more than one) for appropriate diffusion coefficient values for methane-air combustion?
I found some data on the web but not sure about that.
I'm simulating combustion of methane-air mixture including CHT effects with solid. In some cases simulations shows flashback phenomena, not in according with sperimental data.
So i'm trying to find a way to raise the flame front (which usually is really low in simulations) in order to avoid flashback (maybe due to inappropriate transport properties description of the species).
Is this reasoning correct?
What else could raise flame front?
Thanks.
Old   July 1, 2012, 14:11
Talking
faramarz
aerospace1365 is on a distinguished road
Send a message via Yahoo to aerospace1365
hello dear jeff
I want to simulate combustion of h2/air in fluent and I really need to its transport properties. have u any data about like chemKINE file.
best regards.
aerospace1365 is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
binary diffusion coefficient / kevin FLUENT 3 July 1, 2012 14:07
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
binary diffusion coefficient kevin-change FLUENT 2 October 1, 2002 07:02
Who can write the binary diffusion coefficient ?? Hsin-Ping FLUENT 1 April 15, 2002 03:22
