I experience solving error with the following notice during solving a transient problem. In the notice, I have no idea where does the 'max continuity loops' locate, does anyone know where it is? Thanks
| ****** Notice ****** | | The maximum Mach number currently is 2.572E+01. | | If this message persists and you experience robustness problems, | | consider setting the expert parameter 'max continuity loops' to 2. | |
Always list the version that you're using...For 5.7.1, go to expert parameter in Pre..... Browse the menu on top... should locate this item quite easily. Alternatively, write a CCL for it. The former one is the easiest.
Shishir Gautam
Rep Power: 5 ![]() |
In the outline section of CFX-pre, right click on "Solver" and then click on insert. Select expert parameter. Under Expert parameter tab, go to convergence control and at the bottom, there is " High Speed Models" option. Then set the max continuity loop to 2 as suggested.
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
