July 12, 2005, 03:59 |
CFD v.s wind tunnel in airfoil
I tried to compare CFD・s results with wind tunnel test in pressure coefficient(Cp) for a developed airplane with a symmetric airfoil . At trailing edge, CFD proved that uppersurface・s Cp and lowersurface・s Cp close to each other ; but, the results of wind tunnel test speaded apart each other. The wind tunnel test of F-16 ran the same conclusion.Why? Thought W/T only had finit pressureholes , the curves couldn・t diverge at trailing edge. According to Kutta condition, Cp curves of up/low surfaces at trailing edge must meet each other. Were W/T data incorrect ?
Wind Tunnel Blockage question | ohma0043 | CFX | 9 | June 17, 2018 20:19 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 15:07 |
how to setup 3d wind tunnel | bukm | Siemens | 9 | December 13, 2014 16:06 |
ICEM CFD Airfoil Tutorial Input | Tom | ANSYS Meshing & Geometry | 1 | September 25, 2009 07:50 |
wind tunnel correction | Arthur Chen | Main CFD Forum | 2 | September 4, 1998 19:42 |
