Heat Exchanger...TWO
Old   July 9, 2005, 17:47
Default Heat Exchanger...TWO
Walid
I am a new CFX user and the only version that I can use is CFX 5.5.1. I have posted a question on this forum last month with title: Heat exchanger. I received a number of replies but none of them seems to answer the question.
I would be grateful if any one has a previous experience in simulation of heat exchanger condenser can help me on this. Please, see to the previous question on Wed, 22 Jun 2005, 5:09 p.m. for details.
Below I show the reference case and CFX result for a heat exchanger tube;
Design case as reference;
Tube lenght is 8 m Tin=70'C Tout=85'C Tube Diameter is .02 m Wall Temperature (fixed) is 90'C
CFX result;
Tube lenght is 8 m Tin=70'C Tout=90'C Tube Diameter is .02 m Wall Temperature (fixed) is 90'C
I noticed the fluid reaches the wall temperature before passing 1/3 of tube length which contradicts the design data.
Is this reasonable result from CFX? Or I have made a mistake somewhere?
I appreciate any help…
Old   July 10, 2005, 19:59
Default Re: Heat Exchanger...TWO
Sounds like you need to do some reading into wall heat transfer modelling. Have a look at some heat transfer validation studies (the CFX Community has some available for download) and textbooks - Turbulence Modelling for CFD by Wilcox is a good one.
Old   July 11, 2005, 20:04
Walid
Dear Glenn Horrocks,
Thank you for your advice and for previous reply, I have already covered the topic theoretically but the simulation results are a bit weird. I will try to find some previous studies.
Thnaks
Walid
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 02:29
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 14:52
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
Heat Exchanger Simulation tightaznbreaka FLUENT 0 March 18, 2010 16:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
