June 30, 2005, 00:02 |
Axial rotor tutorial
Hi, I was going through the tutorial on Axial rotor and stator and I found that the mesh on the rotor is different from the one on the stator. Could someone kindly give an explanation for this? Thanks Vicky
July 4, 2005, 03:01 |
Re: Axial rotor tutorial
how are the meshes different. If they have different pitch angle this is not a problem because you can specify pitch change on your interface.
July 4, 2005, 03:07 |
thanks, i got that after some time of looking thru it. regards,
axial and z-velocity difference? | user0314 | FLUENT | 1 | May 27, 2016 12:30 |
how to plot out circumferentially mass averaged axial velocity in a rotor? | wildli | FLUENT | 0 | July 17, 2010 15:54 |
Transient axial rotor/stator convergence issue? | Nicola Viscanti | CFX | 3 | March 17, 2010 04:15 |
Surface streamlines on axial flow fans | Jennifer | CFX | 2 | February 17, 2009 14:50 |
About the design of axial fans | HanCheolHeui | Main CFD Forum | 0 | September 8, 1998 10:13 |
