June 29, 2005, 16:07 |
turn off k-epsilon model
I am trying to modeling solidification using a single phase model in which the solid is simulated by using temperature specific source terms. As a result some locations are turbulent (liquid, about Tcrit) and other locations are laminar ('quasi-solid', below Tcrit). I have been using a k-epsilon turbulence model; however I am concerned that the heat transfer in the laminar regions is not accurate due to the k-epsilon model.
Does anyone have advice about how I can improve the thermal modeling in the laminar regions? -Should implement a thermal phase change so that phase specific flow models can be used -Or is it possible to turn off the k-epsilon model in another way. Advice is greatly appreciated Malcolm |
June 30, 2005, 07:47 |
Re: turn off k-epsilon model
I don't know if it will help you, but take a look at: http://www-waterloo.ansys.com/cfxcom...minar_flow.htm |
June 30, 2005, 13:29 |
Rui,
That looks great!! Thanks for the link. Malcolm |
Atomization and Breakup model | xck1986 | OpenFOAM | 4 | May 31, 2014 05:43 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 11:36 |
Curvature Effects using the Standard K Epsilon Model | syler3321 | CFX | 2 | October 19, 2010 21:53 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 21:51 |
