Hi! Could CFX5.7.1 run Parallel process in Windows and Linux at the same time?
I tried with 5.6 and it was possible. I don't know if 5.7.1 can do it, but I think that PVM tech doesn't change with CFX version.
good luck |
Yes you can, if you are using PVM. I have a windows and HP-UX running in parallel. Regards Jens |
Parallel run of OpenFOAM in linux and windows side by side | m2montazari | OpenFOAM Running, Solving & CFD | 5 | June 24, 2011 03:26 |
FLUENT in Windows Serial and Linux Parallel | sham83 | FLUENT | 0 | May 31, 2011 23:38 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Parallel Processing Between Windows and Linux | Amir | FLUENT | 0 | February 18, 2005 12:33 |
