Sloshing Pressure level settings
Old   January 5, 2019, 16:27
Question Sloshing Pressure level settings
Aashi
Aashi171185 is on a distinguished road
Sir in my sloshing analysis i came across inverted pressure levels as at time t=0 sec (kind of before loading) all the pressure shown is only hydro-static pressure. but when i do the analysis of closed tank with fluid height 0.5 m its hydro-static p would be around 4895 [pa] which is max at bottom and gradually decreasing towards 0 value but in results it shows opposite pressure levels as shown in fig cfx hydro-static.
and when the same analysis is done with small opening on top wall with the same fluid height it shows correct pressure levels as shown in cfx hydro-static 2. why is this happen? is it mandatory to perform the closed tank analysis with small opening in cfx? or is it any other pressure setting issues??????
Aashi171185 is offline   Reply With Quote
Old   January 5, 2019, 17:13
Chris
Cheese is on a distinguished road
Did you change the reference pressure? Try to plot the absolute pressure for the first simulation " cfx hydro-static"
Both results are the same. The static pressure is increasing downwards. I do not see the problem.
Cheese is offline   Reply With Quote
Old   January 6, 2019, 09:34
Question Sloshing results seems to be inverted
Aashi
Sir how these results seem to be same and why in this case the static pressure is decreasing downwards as my reference pressure is same in both the cases. i think they are inverted as compared with each other
how can i change the pressure level setting i want that static pressure decreases upward like at bottom 4606[pa] and at fluid surface 0.0[pa]. can any one please tell me
Old   January 6, 2019, 09:45
Chris
In which scenario the pressure is decreasing downwards? In both pictures the values are rising downwards. Since you have negative values in the first simulation i would have expect another reference pressure. Did you try to plot the absolute pressure in cfd post? If itīs not the reference i do not know the answer. May someone else have an idea.
cfx
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
sound pressure level Zeljko CFX 1 March 21, 2018 12:41
pisoFOAM (LES) - internal pipe flow - convergence gu1 OpenFOAM Running, Solving & CFD 0 January 11, 2018 17:39
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
tank sloshing - getting wrong pressure enghamed CFX 2 April 26, 2011 23:09
