Phase materials ---temperature
Old   June 22, 2005, 16:44
Default Phase materials ---temperature
Jack
Hi, all
I am trying to use a water phase and a air phase at 3C degree in my model. I also need to change the temperature to other values later. However in cfx it seems that the material properties are only available at certain standard conditions.
So, do I need to generate new material manually or are there easy ways to do it? Thanks!
Regards!
Jack
Old   June 22, 2005, 20:15
Default Re: Phase materials ---temperature
Yes, you can generate new materials. The easiest way is to take the existing water or air fluid and just modify the bits you need.
You can also make properties functions of temperature. You can use this to either simply calculation of fluid properties at different conditions for a series of constant properties simulations, or to conduct a variable properties simulation.
Regards, Glenn Horrocks
Old   June 22, 2005, 21:52
Jack
Thanks, Glenn
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Eliminating exchange energy between phase in Granular Temperature diff eqn. cfdbusiness FLUENT 0 February 2, 2010 23:30
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
