Setting problem of the bubble induced turbulence in CFX |
January 3, 2019, 12:32 |
zhubohong
Rep Power: 8 |
Hello, guys, anyone can help me? My questions is as follows:
CFX has its own model (Sato model) to predict the bubble induced turbulence. However, I want to use the another way to do it. That is modifing the source of k-e turbulence model accroding to Pfleger and Becker's work. The equation can be found in attached figure. So, My problem is how to add this equation in CFX, how to edit this equation? For example, how to edit the item of total interphase force. |
January 4, 2019, 02:51 |
Rep Power: 144 |
You can add extra equations as a turbulence source term. But you cannot edit the fundamental turbulence equations.
January 4, 2019, 03:02 |
#3 | |
zhubohong
Rep Power: 8 |
Currently, the major problem for me is how to edit the attacted equation in CFX expression. For example, the attacted equation is a function of total interphase force, I don't know how to edit it in expression. I checked the "ANSYS CFX reference Guide", but I still find a sovled method. |
January 4, 2019, 03:08 |
Rep Power: 144 |
The equation was not attached. Please post the attachment again.
January 4, 2019, 03:20 |
#5 | |
zhubohong
Rep Power: 8 |
The equations come from the reference"D.Zhang et al. Chem. Eng. Sci., 2006, 61, 7593" |
January 4, 2019, 06:51 |
Rep Power: 144 |
Defining the terms might help...... What is S_K,BIT and S_E,BIT?
January 4, 2019, 07:06 |
zhubohong
Rep Power: 8 |
Sorry for this, please check the new attached figure. Thanks
January 5, 2019, 06:24 |
Rep Power: 144 |
They appear to be just source terms on the k and e equations. So just add them as a source term.
January 5, 2019, 07:11 |
#9 |
zhubohong
Rep Power: 8 |
January 5, 2019, 18:07 |
#10 |
Rep Power: 144 |
Yes, you apply source terms in sub-domains. Sub-domains can be the whole domain if you like.
January 6, 2019, 09:23 |
#11 |
zhubohong
Rep Power: 8 |
Thanks, the attched figure shows my new question. May you give me some tips?
January 6, 2019, 18:46 |
#12 |
Rep Power: 144 |
Yes, your Argon to Liquid relative velocity vector is a vector (obviously), and the k source term must evaluate to a scalar field (obviously, k is a scalar field). So you are going to have to convert your vector to a scalar somehow. You are going to have to determine the appropriate way to do that as there are many ways. The reference you got this function from will probably tell you how to do it.
The most obvious thing is to take the magnitude of the relative velocity vector, but this might not be correct so it is up to you to choose the best method.
Grids problem in CFX (imported from ICEM) | Anna Tian | CFX | 10 | July 9, 2015 10:44 |
Turbulence Model Parameter Setting Up- Vortex Shedding Problem | nima_nzm | Main CFD Forum | 4 | June 12, 2015 10:43 |
CFX convergence problem simulating ogive-cylinders at varied angle of attack | jdacosta | CFX | 6 | February 25, 2015 22:42 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
