January 1, 2019, 13:14 |
Air Heating Up Rapidly
Thomas
Rep Power: 7 |
Hey guys,
I have made a transient cfx simulation consisting of two concrete slabs and air between them (with steel members too but this is irrelevant). I have defined all the materials and boundary conditions and i am heating up with temperature (time dependent) one side (wall) of the "sandwich". My problem is that after convergence post shows that actually concrete heats up at a reasonable rate that makes sense but the air in-between has unexplained crazy high temp. What am i missing? Cant find what the problem is.... I am a beginner in CFX (actually is my first simulation) coming from the mechanical background so be gentle |
January 2, 2019, 05:24 |
Rep Power: 144 |
Is your simulation adequately converged? I strongly suspect not. Converge to a tighter tolerance. Also, for Conjugate Heat Transfer (CHT) simulations like this you should include imbalances in the convergence criteria. Residuals alone are a poor estimate of convergence for CHT simulations.
January 16, 2019, 14:20 |
Thomas
Rep Power: 7 |
Hey thanks for your answer! I will check it out thoroughly during the next days and come back to you, if there is any progress.
ansys 16, cfx & air content, heat transfer, transient |
Air at High Pressure | cfd seeker | FLUENT | 2 | September 30, 2013 14:58 |
Is it possible to integrate air through a system with mixture of air and water? | Hale | OpenFOAM Post-Processing | 1 | September 30, 2013 08:57 |
air distribution and heat transfer | wasim_kassel | FLUENT | 0 | June 24, 2013 11:12 |
Air to Air Heat Exchanger | visser1975 | FLUENT | 2 | November 10, 2012 13:34 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
