Changing an Option selection using CEL.
Old   January 1, 2019, 06:59
Default Changing an Option selection using CEL.
AH
visitor is on a distinguished road
Can anyone help please?
Looking for away to change an Option through CEL in CFX.
Example from
Option = Adiabatic
to
Option = Non Adiabatic
I do know the nested IF statement in creating an IF and ELSEIF conditions. However how do i create a switch between these options? Say example if the temperature =< 400 K, then Adiabatic elseif Non Adiabatic.
Thanks in advance.
visitor is offline   Reply With Quote
Old   January 2, 2019, 06:22
Rather than switch between non-adiabatic and adiabatic conditions, why not just define it as a non-adiabatic condition (with a heat flux I presume), and then for the times it is adiabatic just define the heat flux to be zero. Then the if statement is a simple numerical one.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   January 2, 2019, 07:42
AH
Thanks for your reply.
Need to change automatically from within CEL. With an if condition statement. Have tried it, but didn't work.
Working on a student version, if it makes a difference.
Old   January 2, 2019, 23:18
Student version of CFX/ANSYS is the same as the full commercial version, just the number of nodes in the mesh is limited and not all the physics is available.
You cannot change the boundary condition type with a CEL if statement. When you change boundary condition type you need to run it through CFX-Pre again to update things, you cannot do it with a CCL update alone.
Your options are:
* Use the method I described in my previous post
* Stop the simulation, and restart using a new simulation with the boundary condition updated to the new type and use the old simulation as an initial condition.
That's about it. You cannot change boundary condition type inside a run and continue the run.
Old   January 3, 2019, 09:54
Thumbs up
AH
Thanks for your reply Gohrrocks.
May be i will look into Fluent, just incase there is away.
Thanks
Old   January 4, 2019, 02:49
Why? Stopping and restarting is simple, easy and can be automated if necessary. Is that not acceptable?
Old   January 4, 2019, 07:29
AH
Yes definitely, can be done. Just was looking for an automated way. Something like what a UDF does in Fluent. Will explore a way with Fluent, so far found nothing in user manual.
Thanks.
Old   January 4, 2019, 12:29
Opaque will become famous soon enough
This is supported as a multi-configuration setup.
First analysis uses adiabatic as the Option, and the second analysis uses Flux In as the option.
The switching between the options is automatically taken care of once the trigger (logical) is satisfied.
Opaque is offline   Reply With Quote
Old   April 1, 2019, 07:34
AH
Thanks for your replies.
Was hoping to automate this to get more control. I think even fluent won't make it with a udf.
Thanks again.
cel, conditions, option
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
