Negative quality elements in ICEM Grid
Old   June 16, 2005, 08:36
Default Negative quality elements in ICEM Grid
Kartik
Hi
I use ICEM CFD to mesh a cascade. i get negative quality in quality check only on the suction side of airfoil. And at a particular point, the grid is clustered though i have not clustered the grid. Also at some spots meshes overlap.
Kindly suggest me some remidy and the probable reason
Thanks Kartik
Old   June 16, 2005, 10:00
Default Re: Negative quality elements in ICEM Grid
Myron
I would check edge projections/associations first. You can also view the edges with the projected shape (Edges options Nodes)
Old   June 17, 2005, 05:45
TB
What mesh are you using? Try hexa. If you're using tetra, then try CFX-Mesh.
ICEM CFD - preset quality criteria JSM CFX 2 May 8, 2008 00:36
Exporting ICEM Tetra Grid to Fluent with Hexa-Core Tim FLUENT 2 August 30, 2007 08:16
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 19:18
