Post-processing Pressure in a boiling simulation |
December 24, 2018, 15:19 |
Soumitra Vadnerkar
Rep Power: 8 |
In a subcooled pool boiling simulation under normal atmospheric pressure, am I expected to see rise in pressure level of the liquid phase with time (transient simulation).
I set reference pressure in Pres-processing (ANSYS CFX- Pre) for the domain to be 1 atm and initial condition to be 0atm pressure, still in post processing (ANSYS CFD-Post), I see Pressure contour variable rise ~ 9atm throughout the domain. |
December 25, 2018, 06:46 |
Rep Power: 144 |
I do not understand your question.
I think the first line of your question says you expect to see the pressure rise as the liquid boils - this makes sense if it is boiling in a constant volume container. I think the second line of your question says that the pressure has risen to 9 atm. So isn't that what you expect? It does sound like a very big pressure rise, you must have a large heat flux to get that much pressure.
December 25, 2018, 10:53 |
Soumitra Vadnerkar
Rep Power: 8 |
Oh sorry,my bad.
The first line is actually a question. Am I expected a pressure rise in the liquid phase for a subcooled pool boiling under normal atmospheric condition? The pool boiling tank is open to atmosphere from it's top wall (it's a free liquid water surface in contact with atmospheric air (and this atm. pressure)). So it is not a constant volume boiling (also, in simulation, I put Outlet boundary condition with 0 relative pressure). And yes, the is huge flux, because the temperature of the heating medium is about 240 C. (It's is conjugate heat transfer problem). |
December 26, 2018, 04:45 |
Rep Power: 144 |
If the thing is open to atmosphere then the pressure will remain near atmospheric, with some hydrostatic component and a small effect from and fluid motion generated.
If it is open to the atmosphere but you are generating huge pressures then it sounds like something is wrong.
ansys cfx, pressure, subcooled boiling |
Simulation of ball-valve opening w.r.t to varying inlet pressure | wasim_03 | Main CFD Forum | 1 | January 6, 2018 13:40 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 17:29 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
