Domain Imbalance
Old   December 21, 2018, 12:53
Default Domain Imbalance
DDG
DDG is on a distinguished road
Hi everybody
I'm doing some simulations on a Transonic stage, with the 500k-target mesh for both rotor and stator. After 10000 iterations the Domain imbalance for the Energy term is still over 0.01, so I was wondering: should I continue iterate to reach that limit or I can assume the solution as converged?
DDG is offline   Reply With Quote
Old   December 21, 2018, 16:50
Gert-Jan
Gert-Jan will become famous soon enough
Compared to the other terms, the imbalance of 0.1779 is very small. So, why should you continue?
Gert-Jan is offline   Reply With Quote
Old   December 21, 2018, 18:12
DDG
Well, since I'm relatively new to CFD it's something I wasn't 100% sure about it, I had a domain imbalance of roughly for the stator 5E1 and since the usual criterion is <0.01 I was afraid that was a mistake to leave the simulation as it was
Old   December 21, 2018, 18:20
Gert-Jan
0.01 is relative and equals 1%. I guess you already reached that long time ago.
But it is good practice to tighten this convergence criterium. So keep up the good work!
Old   December 21, 2018, 18:23
DDG
Actually, this doubt aroused this morning due to the residuals: for a problem I had in the model, there is a recirculation zone in the stator zone that doesn't allow the solution to converge properly. I checked the efficiency monitor and it was oscillating. I then changed the timestep model and it was still showing a small oscillating tendency, so I was wondering if the imbalance was still too high to have a better converged efficiency
Old   December 21, 2018, 18:27
This looks very similar to the FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 21, 2018, 18:32
Gert-Jan
I would be happy to obtain results like that. Mostly my cases lead to more chaos. ;-)
In your case, it is likely CFX can't find a stable solution, resulting in a oscillating flow solution. Depending on the origin of the oscillation, it sometimes helps to increase the time step by a factor 10, or decrease by a factor 5. Difficult to say.
If the origin is a real transient phenomena, then switch to transient.
Old   December 21, 2018, 18:34
DDG
To tell you the truth I haven't enough time to do a transient simulation, I will try to do the best with what I have now
Old   December 21, 2018, 18:36
DDG
I know this page too well
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Periodic Pressure drop cfd_begin CFX 10 May 25, 2017 08:09
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Rotational porous domain Pifpoffele CFX 1 July 6, 2015 12:46
Domain Imbalance and Conservation target MissCFD CFX 3 May 27, 2015 12:03
