December 20, 2018, 02:02 |
what is the function of mesh stffness?
Rep Power: 7 |
In cfx pre-process, we find a option is mesh stiffness in domain setup.The mesh stiffness have three models: increase near small volume, increase near bounderies, and value.
I do not know the function of these thress mesh stiffness models. And I refer to the help document, find the mesh stiffness is about the mesh move. When i choose the 'value' mesh stiffness model, and change it value, the computer result does not change but avoid create nagetive volume. so,i wannt konw the specific function of these mesh stiffness model |
December 20, 2018, 16:48 |
Rep Power: 144 |
The built in model to do mesh motion uses a diffusion equation to work out the motion of the nodes. This diffusion equation has a diffusivity parameter, which is the mesh stiffness you talk about. This allows you to make some regions of the mesh "stiffer" than others, which if used carefully, can help reduce negative volume element errors.
Also look at the FAQ on this error: https://www.cfd-online.com/Wiki/Ansy..._went_wrong.3F
December 20, 2018, 21:50 |
mesh stiffness
Rep Power: 7 |
the third mesh stiffness model
December 20, 2018, 21:57 |
Rep Power: 7 |
thanks for your help
mesh stiffness |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
