Dispersed Fluid Simulation with Interface between domains
Old   December 19, 2018, 11:19
Default Dispersed Fluid Simulation with Interface between domains
Aleksei
alexksei is on a distinguished road
I am trying to simulate a flow of air with dispersed fluid (water). Dispersed phase (water) is 5% of Volume Fraction at the INLET.
I have two domains (see picture):
https://www.dropbox.com/s/knnl6an378...hot_2.png?dl=0
static and rotational and between them I use FROZEN ROTOR interface. I have problems with CFX to solve this case (overflow error at 6th iteration each time I run the simulation).
The same case but without dispersed fluid works well.
I will be grateful for any good advice on how to solve this.
alexksei is offline   Reply With Quote
Old   December 19, 2018, 17:37
FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
If you make the rotating domain stationary does it converge?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 20, 2018, 02:58
Aleksei
I did several cases:
1. Without dispersed phase (AIR only), stationary domain- converged
2. Without dispersed phase (AIR only), rotating domain- converged
3. Dispersed WATER and continious AIR, only one domain, no interfaces - converged
4. Dispersed WATER and continious AIR, 2 domains, interfaces - OVERFLOW error
From these cases it seems the problem is about interfaces between domains and only when dispersed phase is introduced. When there is no dispersed phase everything works well.
Old   December 20, 2018, 09:29
Opaque will become famous soon enough
Dear Alexsei,
You have not tried the combination of
Dispersed WATER and continuous AIR, 2 domains (both stationary) with interfaces.
You can either set the Rotating domain to Stationary, or set the Angular Velocity to 0. They are different tests, so both results will help.
That is what Glenn asked.
Opaque is offline   Reply With Quote
Old   December 20, 2018, 09:59
M
AtoHM is on a distinguished road
Have you tried initialising/interpolating your converged solution onto the one that doesn't work prior to starting?
This helped me get rid of some problems, the first steps during the run are sometimes critical. Maybe your setup works fine with a good initial guess instead of starting from scratch.
AtoHM is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
