December 18, 2018, 03:17 |
Initial Conditions
Pedro Oliveira
Rep Power: 8 |
I have a doubt:
When I use preview initial conditions with a dispersed fluid with 0,8mm particle diameter for a simulation with all the models and properties the same as that one, except the particle diameter of the dispersed phase of 0,01mm, does it change the particle diameter to the new value, or assumes the one of the inittial values specification? The purpose is to obtain convergence easily and change only the particle diameter |
December 18, 2018, 04:32 |
Gert-Jan
Rep Power: 27 |
It will change the particle diameter to the new one. So your initial guess will adapt to the new diameter rapidly.
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
