June 6, 2005, 06:51 |
How to set an equilibrium-Air model
Hello, I am trying to set an Air equilibrium model for a hipersonic case. The air will be reacting and disociating, but i am going to consider that the reaction time is too fast compared to residence time of the fluid. I have all the properties for reacting Air at equilibrium as tables, like Cp(P,T), and i wish to set up a model with them. Do anyone know how to do that?
June 6, 2005, 13:32 |
Re: How to set an equilibrium-Air model
Find a scheme to apply; that is, what spieces will be assumed to be present and there elementary reaction equations (i.e. H2=H+H, O2=O+O, CO2 = CO+O, . . . , so on). Each of these elementary rxns has an equilibrium constant (normally function of temp.) which must be obtained (if in table => fit these to polynomials.). The air must be thereafter considered as a mixture of these species (mole fractions) with properties that are obtained from those of the individual species, T=T_i, P = sum(P_i), R = sum(R_i*Y_i), M = sum(M_i*X_i), Y_i = (X_i*M_i)/M. where P_i: partial pressure of species i
R_i: gas constant " " " X_i: mole fraction " " " Y_i: mass " " " " and M is the molecular weight. and then p = (\rho)*R*T hoping it would help. |
June 6, 2005, 13:41 |
Thanks, i did it in fact, and i have these all the resultant properties for the mixture in tables. The problem is to implement that in CFX, i think is using the RPG tables formats. But i am still working on understanding them. As soon i got a solution i will post it. Regards Jorge
August 24, 2015, 04:47 |
#4 | |
faegheh
Rep Power: 11 |
i wana know did you run this case, actually i am modeling this case with fluent, and have some question |
August 24, 2015, 07:32 |
#5 | |
Rep Power: 144 |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
[ICEM] How to set bocos on 2D model for ANSYS CFX (tuts no help) | RossFS | ANSYS Meshing & Geometry | 4 | May 22, 2012 09:56 |
multiphase model, water in air? | bugra | Main CFD Forum | 10 | January 2, 2010 14:09 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 02:40 |
