About convergence
Old   May 31, 2005, 00:29
Default About convergence
LQ
I am using CFX to solve a governning stage of a steam turbine which have three domains : the strengthening ring,stator and rotor.
I solved the flow field of the stator first,then added the rotor, finally solved all the three components as a whole stage.
During the procedure,I found that the more domains there were, the longer time will elapse for the caculation to converge.
Is there anybody else has this experience and know the reason?
Old   May 31, 2005, 00:35
Default Re: About convergence
LQ
I mean "the longer time" to the iteration steps.
Old   May 31, 2005, 19:34
I assume you mean a longer total physical timestep to converge. I can see this being caused by two factors, firstly adding extra bits to the model puts longer timescale effects into the model (that is flow interaction between blade rows); and secondly the rows are probably connected with GGI interfaces and they will require a little extra time to converge.
Regards, Glenn Horrocks
Old   June 3, 2005, 00:43
Robin
By "longer time", do you mean wall clock time? I.e. it took more time to run? If so, the answer is simple: you are solving a bigger problem.
The solver run time scales linearly with with number of equations and the number of nodes. Double the nodes, it takes twice as long. Similarly, if you add equations to solve (such as heat transfer, or an additional variable), it takes proportionally longer for each timestep. This does not necessarily mean it requires more iterations. Each run make take 100 iterations, but each iteration get's a bit longer.
Regards, Robin
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 15:20
