Return code 255 (CFX-5.7.1)
Old   May 20, 2005, 06:17
Default Return code 255 (CFX-5.7.1)
Jesper
Hi, The solver closes down suddently with a return code 255 and an additional message saying that their is not enough memory. Could this be because of a large output file? If so, is their a way to reduce the size of the file? Regards Jesper
Old   May 20, 2005, 12:47
Default Re: Return code 255 (CFX-5.7.1)
Rui
What is exactly the message? Copy it from the .out file and paste here.
What is the size of the .out file? I working on a PC with Pentium 4 and 512 MB Ram, and I have had .out files larger than 100 MB without any problem (except that the simmulation takes ages).
What type of simmulation are you performing?
Regards,
Rui
Old   May 22, 2005, 05:03
Tim Guo
Hi, same condition happened to me when I set the particle tracking information in the Solve Control too big. I checked my working directory in which all disk space is filled. You are setting somewhere got problem.
Old   May 22, 2005, 05:04
Tim Guo
Your setting somewhere got problem.
Old   May 23, 2005, 09:03
Jesper
Hi, Then it might not be the size of the out file anyway. The error message I am referíng to was written in the little command window that opens up with solver. Unfortunately it did not copy it. But it was an "out of memory" message, and to me it seemed like the solver had somehow run out of memory. A gui-error is stored in the library of the simulation, with the information:
GUI INFORMATION: RUN MESSAGES: Run FlygtSteadyNN2 004 DISPLAY MESSAGE: m1
Title = An error has occurred in cfx5solve:
Level = ERROR
Message = "The CFX-5 solver has terminated without writing a results file. Command on", "host blue6 exited with return code 0." END END
I am running a paralelle simulation, and opening up the task manager in the start of the run showed plenty of memory left in the RAM. I have made an auto backup of the results, so their is no problem starting up the simulation again from that filw. When restarting the simulation, it stops again after approx. the same number of iterations (11,000, now 22,000...)
Regards Jesper
ANSYS CFX solver exited with return code 2 vmlxb6 CFX 6 June 22, 2017 19:01
Return Codes in CFX fayaazhussain CFX 1 June 16, 2011 19:56
How to creat a mesh to use in CFX 5.7.1 ! Trung CFX 5 September 8, 2010 05:32
return code 47 Fernando CFX 0 May 15, 2008 07:29
Available memory is less than 2GB in CFX 5.7.1 Korsh Mik CFX 3 June 5, 2005 20:34
