heat exchanger in typical air-conditioning system!
Old   May 11, 2005, 09:14
Default heat exchanger in typical air-conditioning system!
Yang Bin
Dear all:
This problem is focused on heat exchanger in typical air-conditioning system. I want to know whether the latent heat transfer caused by condensating of moist air can be coupled with sensible heat transfer in simulation successfully? I want to simulate the whole process when moist air come through the cooling coil in both air side and water side.
I have asked this question for several times. Please help me if you have some experiences in this field. Thank you very much!
Yang Bin From Singapore
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
Heat Exchanger Simulation tightaznbreaka FLUENT 0 March 18, 2010 16:45
Pressure drop in a heat exchanger Diana FLUENT 5 December 13, 2007 10:33
heat transfer - heating element to air in FloWorks Duncan Gravill Main CFD Forum 1 March 28, 2007 21:16
heat exchanger in typical air-conditioning system! Yang Bin Main CFD Forum 0 May 11, 2005 09:16
