Fluid Solid Interaction - divergence
Old   May 5, 2005, 05:02
Default Fluid Solid Interaction - divergence
bebes
I am modeling a wind blade using Fluid Solid Interaction (FSI). I choose Fluid Analysis first.
At the first Solid Analysis, the displacements of the blade are zero. At the second Solid Analysis, the displacements of the blade are about what I expect they are. Afterwards, the displacements of the blade are getting bigger and bigger at each Solid Analysis…
Does anybody already have this problem?
Thank you for your help. Seb
Old   May 5, 2005, 19:46
Default Re: Fluid Solid Interaction - divergence
James Date
Not sure, but it sounds like you need some form of relaxation between the CFD & FEA simulations, but i might be completely wrong!
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? acro CFX 15 September 23, 2016 12:16
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 17:15
Theory behind the solid domain rotation in fluid using Bets property Riken CFX 0 October 28, 2009 10:51
Fluid - Solid Domain Interface Daniel CFX 6 February 15, 2009 19:09
