Solver quits without results saying Return Code 15
Old   May 4, 2005, 13:04
Default Solver quits without results saying Return Code 15
Kramer
Hi there,
i am working on a student research project dealing with the flow around a wind rotor. I am using a mesh with about 1 Million Hexas constisting of two domains, one rotating and one still. My problem is that the solver quits randomly (sometimes after 3 iteration another time after 15) with Return Code 15. Does anyone know what this means?
Please help.
Kind Regards
Old   May 4, 2005, 14:29
Default Re: Solver quits without results saying Return Cod
Juan Carlos
Hi Kramer,
What operating system are you working on? In Unix (AIX,IRIX,SUNOS,HPUX,LINUX) 15 can be a SIGTERM from the system or at login out..
Regards, Juan Carlos
Old   May 4, 2005, 15:24
Kramer
Thanks for your hint, but im running a windows xp based system (2 Nodes, 1 x Athlon XP 2,2 GHZ 2GB RAM,1 x Pentium 4 3Ghz 2 GB Ram). I was able to make a run with 256 iterations and again there was the error message from the solver. Return Code 15?? Is there something like a list for the different Codes XX where it is described what they mean ?
Old   May 4, 2005, 15:52
Juan Carlos
That code comes from the OS (windows in your case).. CFX usually writes messages of different kinds.
You can always contact CFX support.. Good luck, Juan Carlos
Old   May 5, 2005, 08:08
Kramer
Well, it doesnt seem to be a windows code since it is the solver saying:
+--------------------------------------------------------------------+ An error has occurred in cfx5solve:
The CFX-5 solver exited with return code 15. No results file has been created. +--------------------------------------------------------------------+
End of solution stage.
How should the solver reveal a OS-message? What do You think?
Old   May 5, 2005, 19:55
Can you post the last page of the output file? That might help diagnose the problem.
Old   May 6, 2005, 05:02
Kramer
Hi Glenn,
here are the last two iterations. The simulation crashes everytime at a different iteration number, so i don't think that it is a problem with the mesh,Pre or BC. Do you know that behavior?
OUTER LOOP ITERATION = 186 CPU SECONDS = 4.79E+04
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom | 0.99 | 2.9E-03 | 3.5E-02 | 3.0E-04 OK|
| V-Mom | 1.00 | 3.6E-03 | 1.2E-01 | 2.3E-04 OK|
| W-Mom | 1.00 | 3.1E-03 | 9.3E-02 | 2.5E-04 OK|
| P-Mass | 0.99 | 2.2E-05 | 1.7E-03 | 9.5 3.5E-02 OK|
| K-TurbKE | 0.98 | 1.3E-02 | 3.3E-01 | 5.8 7.7E-08 OK|
| E-Diss.K | 0.97 | 4.7E-03 | 2.9E-01 | 11.7 3.5E-08 OK|
OUTER LOOP ITERATION = 187 CPU SECONDS = 4.81E+04
| W-Mom | 1.00 | 3.1E-03 | 9.1E-02 | 2.5E-04 OK|
| K-TurbKE | 0.98 | 1.3E-02 | 3.2E-01 | 5.8 7.7E-08 OK|
| E-Diss.K | 0.97 | 4.6E-03 | 2.9E-01 | 11.7 3.5E-08 OK
OUTER LOOP ITERATION = 188 CPU SECONDS = 4.84E+04
| An error has occurred in cfx5solve: |
| The CFX-5 solver exited with return code 15. No results file has |
| been created.
Kind Regards.
return code 255 alinik CFX 3 May 16, 2013 01:24
return a normal number to solver in double precision mode in udfs payam_IUST FLUENT 1 February 13, 2012 08:06
Export CFD Solver results to text file format Maik Main CFD Forum 2 May 23, 2008 02:34
Return code 255 (CFX-5.7.1) Jesper CFX 4 May 23, 2005 09:03
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
