Source point for fuel injection.
Old   May 3, 2005, 16:52
Default Source point for fuel injection.
Tony
Can I inject fuel through a source point in the domain just like a boundary inlet?
I tried "Continuity" in the point source, but I didn't see fuel in CFX-post after several timesteps.
Thank you very much.
Old   May 3, 2005, 19:31
Default Re: Source point for fuel injection.
How have you set your fuel model up? Is it single phase, multiphase, particle/droplets or what? Are you sure you have set your fuel model correctly, and correctly specified it at the source point?
Regards, Glenn Horrocks
Old   May 4, 2005, 10:02
Tony
Thanks for your reply, Glenn.
I added this source point into my existing worked simulation, which has a single phase combustion model using EDM. This source point is to simulate a fuel injection port in the combustor. I don't want to have complex mesh so a source point would be better.
T want fuel to be injected through this source point at a fixed mass flow rate, say: 0.0002 kg/s. After specifing a fixed value(0.0002kg/s) for "total mass source", I also use "sink" option to set the species mass fraction values, turbulence parameter values, and X-direction velocity(10m/s).
My questions: 1. What's the relation between the total mass source and the velocity value in the "continuity" option.
2. To maintain a fixed mass flow rate at this point, what should I do?
Thanks again.
surface injection or point injection? sukura_1984 FLUENT 0 September 2, 2009 10:26
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
UDF to define source term at every grid point Ralf Schmidt FLUENT 0 September 21, 2006 12:32
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
