Flow Through Porous media
Old   May 3, 2005, 10:39
Default Flow Through Porous media
Kumar
Dear CFX users,
I am trying to simulate 2-D axis-symmetric flow (TWO-PHASE) through a 8mm thick perforated plate (model as a porous media) using CFX4.4. The volume porosity is 0.25. The plate has 360 holes (250mm diameter). I would like to know how to calculate the following terms for CFX 4.4 command file.
BODY FORCE, RESISTANCE CONSTANT and RESISTANCE SPEED FACTOR
Thanks for help Regards, Kumar
Old   May 4, 2005, 08:14
Default Re: Flow Through Porous media
Bak_Flow
there are correlations and experimental results available. You could use a modified Ergun equation (which is for packed spheres given a specified porosity) or find something more appropriate in a reference such as:
Handbook of Hydraulic Resistance, Third Edition by Idelchik
regards,
Bak_Flow
Old   May 4, 2005, 09:04
Kumar
Old   May 4, 2005, 09:05
Kumar
Thank Bak_Flow I got the flow resistance for the plate K= 20(non dimensional) from Miller book, but I want the value for RESISTANCE CONSTANT (kg/m^3) and RESISTANCE SPEED FACTOR( kg/m^4).
Regards, Kumar
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 05:50
no converge - for Low Re Porous media seepage flow lee CFX 3 August 31, 2007 02:12
Modeling porous media flow in prostar Nirmal Kumar Pathak Siemens 8 November 23, 2005 08:18
Flow resistance of porous media Desheng Kong Main CFD Forum 3 December 19, 2000 12:07
