November 26, 2018, 07:23 |
Fixing "dirty" geometry for CFD
HS
Rep Power: 11 |
I am trying to repair artery geometries with a bifurcation where a side branch has been merged with a main vessel, this creates an overlap and therefore there are surface geometries within the lumen itself at the bifurcation. I have found a technique in GeoMagic where I can remove these surfaces, however it’s an extremely time-consuming business (4ish hours)! I am trying to come up with methods where these unwanted surfaces can somehow be removed automatically. Any thoughts? Thanks. |
November 26, 2018, 08:23 |
Gert-Jan
Rep Power: 28 |
My first guess would be to use Spaceclaim for this.
November 26, 2018, 08:25 |
urosgrivc
Rep Power: 12 |
Design modeller has some nice geometry clean up fetures but every problem needs its own approach,
You will have to be more clear about your geometry (why are there surfaces in the first place) as I don't think much help can be given upon this question as it is just too general. This question is more like; my car doesn't work... what is wrong with it? there is simply no direct answer to this question Ok I can propose a solution: delete the surfaces .. did it help? if you are working with STL or other polygon based cad files, than SpaceClaim is definitely the way to go |
November 26, 2018, 08:47 |
Lance
Rep Power: 22 |
If you are using .stl surfaces (triangles) my go-to solution is to surface mesh it in ICEM, and generate a CAD surface out of that. Much easier to cut and merge compared to stl.
ansys, cad model, geometric reconstruction |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 14:02 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 14:49 |
Geometry for Confined Circular Jet | Greatness | FLUENT | 0 | October 1, 2013 06:04 |
Export geometry file from ansys mechanical | browns6 | Structural Mechanics | 0 | August 27, 2013 17:19 |
2D geometry to 3D geometry | Sgonzalezg | ANSYS Meshing & Geometry | 11 | April 8, 2011 12:02 |
