April 27, 2005, 01:42 |
CFX file format
Somebody among you can provide the mesh file format of CFX? I would like to write a mesh converter for CFX mesh file for some codes which I am writting. Thanks in Advance ! Regards, Sreevisakh |
May 3, 2005, 12:16 |
Re: CFX file format
The file format is proprietary.
Fortunately if you have CFX you can write your own grid importer using the libraries supplied by CFX. Lookup the documentation on user grid import. There is a C API for doing this. Neale |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
