Interface connection
Old   April 22, 2005, 21:29
Default Interface connection
Gab
Hi,all
I have a question about interface connection. If one side has different size with the second side,can I still set up interface connection(fluid to fluid, no movement) between them?
For example, one side is a plane, another side is also a plane but has a hole on it.
Thanks!
Gab
Old   April 22, 2005, 21:37
Default Re: Interface connection
Gab
like this: -------- ------- ------------------
a small parts of the mesh are not overlapped,
Old   April 22, 2005, 21:39
Gab
Sorry, like this:
Old   April 23, 2005, 07:23
deLuther
CFX manual (and presenttions on GGI) says that you can do this - they illustrated possible use of GGI by example where to pipes are connected to flat (some side of chamber...) surface. All you need is similar resolution of both sides (nodes and elements are not matching).
Old   April 23, 2005, 09:24
Gab
Thanks,deLuther. I will do a simple test to demonstrate that.
Best regards!
Gab
Old   April 25, 2005, 19:42
Yes, you can do this using a GGI interface. It is recommended that the mesh be of similar size on both sides of the interface, but it can handle different sized meshes if required. This effectively is a rapid change in mesh element size and that is always challanging for the solver, but as long as your simulation is stable enough in that region it works OK.
Note that the exposed section of the interface will be treated as a slip wall. CFX 5.8 coming soon has the option of making these exposed sections no-slip walls.
Old   April 27, 2005, 11:43
Gab
Thanks for the infromation.
Gab
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Interface connection between domains sujay OpenFOAM Programming & Development 0 April 28, 2010 04:15
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
