the value of saturation pressure of water at 25C |
November 19, 2018, 10:03 |
Artem
Hello!
Sorry if my question is silly. I've read and done tutorial "Drop curve for cavitating flow in a pump". Water at 25 C and Water vapour at 25 C are used in this tutorial. Saturation pressure for them stated as 3574 Pa (Domain settings/Fluid pair models/Mass transfer/Cavitation). I googled "water saturation pressure at 25 c" and all links say that it is 3169 Pa at 25 C. Why is that and is it important for cavitation calculation? By the way in the material properties of Water at 25 C the value of Reference Pressure (I think it is the same as saturation pressure) is equal 3169 Pa. Thanks in advance! |
November 19, 2018, 16:59 |
Rep Power: 144 |
As a tutorial you can set the saturation pressure to be anything you want. It is just demonstrating how to use the software, not how to do an accurate simulation.
Also note that if the water is not pure the saturation pressure will change. You could give them the excuse that the water they are using is not pure and it has moved the saturation pressure a bit.
November 20, 2018, 09:18 |
Artem
Thank you!
saturation pressure, water at 25c |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 21:05 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 19, 2018 00:39 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 07:56 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 12:59 |
