Transonic Rotor Convergence problem
Old   November 19, 2018, 07:48
Default Transonic Rotor Convergence problem
DDG
DDG is on a distinguished road
Hi everybody,
I'm analysing a transonic rotor at ISA conditions (rotational speed w=20260 rpm), I've used the Total P Inlet - Mass flow outlet boundary conditions. Firstly I used the Auto-timescale option, which did give me some sort of convergence but the Turbulence residuals were oscillating a lot. I used then a Physical timescale (time factor= 4*E-5) but although the residuals were reaching a plateau the oscillation was even more accentuated. I then used the local timescale, in this case, the solution is damping but still not converging.
On the other hand, the residuals are quite high (only the mass residual lower than 1*10-4).
I'm open to suggestions
P.S. The mesh I used has >250000 nodes, y+=1.08
DDG is offline   Reply With Quote
Old   November 19, 2018, 17:00
FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   November 22, 2018, 08:26
DDG
Originally Posted by ghorrocks View Post
Hi ghorrocks, thanks for your reply,
Actually, I have already read this page and I managed to reduce the oscillation in the residuals. I used the High Velocity Option and a Local Timescale setting. Although my efforts there is still a smaller oscillation in the residuals, while in my output parameters, the pressure ratio and the efficiency, the oscillation is really feeble but is still there.
In the CFX documentation I have read that
"If the period of oscillation of the residual plot changes by changing the time step size, then the phenomenon is most likely a numerical effect."
Is it possible to eliminate this numerical effect (if it is the problem I'm facing) , and if not how is it possible to validate the model? May I use an average of these output parameters?
Old   November 23, 2018, 04:18
The FAQ discusses this - try a larger time step and see if it fixes it. And the FAQ also mentions that have a look to see if the result is sufficiently converged despite the lack of residual convergence.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 08:27
Problem in implementing cht tilek CFX 3 May 8, 2011 09:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
