Direction of rotation
Old   April 19, 2005, 21:41
Default Direction of rotation
Gab
Hi, All
I am doing tutorial 15: multiphase mixer. In that tutorial, the rotation speed of the impeller domain and shafts were set as 84 rpm. I was wondering what's the direction of the rotation. If look from up to down, do they rotate clockwise or counter clockwise? (I guess it's counter clockwise)
How can I show the rotation direction in cfx-pre or cfx-post?
Thanks
gab
Old   April 20, 2005, 05:26
Default Re: Direction of rotation
Kiddo
It says that "Set Rotation Axis to Global X. " at page 306, so it means it rotates along X-axis with Right-Hand rule. The rotation direction is well defined.
Old   April 20, 2005, 10:34
Robin
To view the rotation, create a vector plot of "Velocity in STN Frame" (using hybrid values) on the walls of your rotating domain.
-Robin
Old   April 20, 2005, 10:42
Gab
Thanks, Kiddo and Robin.
If use right hand rule, the rotation direction should be counterclockwise. However,look at the blade angle shown in figure 1 of that tutorial, I understand that the rotation direction should be clockwise.
Can you further clarify this?
Thanks, with best regards!
Gab
Old   April 20, 2005, 11:41
Kiddo
Because in page302, it set the domain as rotating, so the flow vector is refered to the rotating frame (Just imagine you are in the ratating domain and the flow vector shown is what you will see)
Old   November 16, 2017, 14:51
Default problem in seeing vectors rotational in rotating periodic flow
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Originally Posted by Kiddo
;71710
Can anyone tell me how to plot vectors in rotating flows in Fluent. I have a geometry periodically rotating about z-axis and when I see vector in a plane I do not see any rotational flow in the cavity formed in geometry as shown in figure.
Shamoon Jamshed is offline   Reply With Quote
Old   November 16, 2017, 17:19
Try the fluent forum.
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Direction of Rotation of Radial Turbine ghoshi1983 CFX 8 June 19, 2012 11:16
Axis of rotation for centrifugal compressor Mattia FLUENT 4 October 22, 2007 12:05
Regarding the rotation direction HSeldon FLUENT 2 October 9, 2006 04:30
Relief Plots in CFX Michael CFX 15 June 30, 2006 09:01
