April 14, 2005, 10:56 |
Porous Flow and Data CFX 4.4
Some question regarding porous media in CFX 4.4 (1) To write out data using USRTRN, is the normal syntax still valid. For example, if I wanted to write out TEMP values in SOLCON I would just state WRITE (90, *) T(INODE,IPHASE). SO similarly, is this valid for the porous region as long as the region of interest has been specified in the 'write' section of the USRTRN (i.e. the porous region) (2) An annulus cylinder, where inner cylinder is non-porous and the outer region is porous. If I wanted to say that SCAL 2 is only to operate in porous region, is this possible? If so, any hints? Many Thanks, Hopefully my questions make some sense... RK |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 03:10 |
Plasma Flow Modelling using Source term and cell's data | Constantine | Fluent UDF and Scheme Programming | 2 | May 19, 2010 22:06 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 04:03 |
Exp. data for transonic flow | J. Held | Main CFD Forum | 4 | April 1, 1999 23:21 |
