Laminar Separation
Old   April 13, 2005, 07:52
Default Laminar Separation
Adam
Does anyone know if CFX5 can accurately predict laminar separation when using the laminar 'turbulence model'?
I am interested to know as it claims to predict separation transition with its new transition model, but am unsure whether it uses a separate feature to attached transition.
Many thanks
Adam
Old   April 13, 2005, 19:27
Default Re: Laminar Separation
Hi Adam,
If you are asking can CFX5 accurately predict laminar flows with separations, the answer is yes. There is no need for turbulence or transition models if the flow is laminar.
Or are you asking about the transition models?
Regards, Glenn Horrocks
Old   April 14, 2005, 07:33
Adam
Thanks Glenn,
I was ultimately enquiring about the ability to model separated transition, so was wanting to know if it could accuratley model non transitional laminar separation.
This is because the transition model utlises one correlation for all types of transition, and I'm not sure how physically accurate that correlation would be.
Also I was trying to understand whether the model required a special set of equations for separated transition.
Regards
Adam
Laminar separation bubble Axilleas Tsompanos FLUENT 5 August 6, 2004 13:24
Laminar boundary separation yongsheng Fidelity CFD 2 March 26, 2003 17:04
V2F model and laminar separation Romuald Main CFD Forum 1 February 17, 2003 05:05
Laminar bubble separation Daniel Bruno FLUENT 0 May 11, 2001 00:11
laminar separation on hydrofoils Günther Migeotte Main CFD Forum 9 August 4, 2000 10:04
