April 12, 2005, 20:53 |
radiation on interfaces
Hello!!
I have to put a thermal radiation boundary condition (emissivity)on an interface between a solid domain and a fluid domain (air: non partecipating media). Have I to put same value of emissivity for both sides of the interface? Can I set an emiss=0 for the air side and an emiss=0.98 for the solid side of the interface? Am I rigth or this setting will give some problems? Last question : when should I use "conservative interface flux" for a fluid-solid interface? I use the monte carlo model Thank you all for the help |
April 13, 2005, 19:31 |
Re: radiation on interfaces
It depends whether you want to model radiation in the solid or not. If the solid is transparent (eg glass) then radiation can propagate through the solid. If the solid is opaque (eg steel) then radiation cannot propagate and radiation can be turned off for that domain. In this case the interface boundary condition allows you to set an emissivity on one side of the interface only. Therefore you use "conservative interface flux" at the fluid-solid interface for radiation when the solid is transparent and you model radiation; you set emissivity and diffuse fraction if the solid is opaque and you do not model radiation in it. Regards, Glenn Horrocks |
Subdomain or Interfaces (CHT) | sandeep_tu | CFX | 8 | July 14, 2009 12:06 |
Multiphase radiation in CFX | Luk_Fiz | CFX | 5 | March 17, 2009 04:51 |
Radiation and interfaces | Frank | CFX | 2 | June 22, 2005 12:26 |
Radiation: definitions | visatron | CFX | 7 | January 8, 2004 16:25 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 06:56 |
