adaptive time
Old   April 8, 2005, 11:08
Default adaptive time
ousegui
Hello Does anybody used a subroutine to calculate adaptive time, which could help me thank you
Old   April 10, 2005, 19:38
Default Re: adaptive time
The next verion, CFX 10 (They are not calling it CFX 5.8 because they want the numbering to be the same as the ANSYS FEA code) which is currently in beta testing includes adaptive time steps which you can set from CFX-Pre. If you contact CFX support they may be able to give you the beta version to try it out.
regards, Glenn Horrocks
Old   April 10, 2005, 23:53
Jeff
At the end of the Solver Modeling online manual, under User Fortran, there is an axample code for adaptive time stepping. It's pretty straight forward.
Jeff
Old   April 11, 2005, 05:14
ousegui
I found the subroutine thank you
Old   April 11, 2005, 11:04
ousegui
Hi have you already use this subroutine. I have some difficulties to use it
Old   April 11, 2005, 23:37
Jeff
You need to be more specific...
Does it compile? Does it link? Does it get called from the solver?
Jeff
Old   April 12, 2005, 03:31
ousegui
it compile using cfx5mkext but the solver did not work. always an error message even i verify the library path and ....:
ERROR #001100279 has occurred in subroutine ErrAction. Message: Unknown user routine User tstepcontrol.
ERROR #001100279 has occurred in subroutine ErrAction. Message: USER ROUTINE: User tstepcontrol could not be loaded. Please check the Library Path, Library Name and Calling Name. For FORTRAN user routines, the Calling Name should be in lower case.
Old   April 18, 2005, 10:31
ousegui
have you any idea?
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
CFX-10 - Adaptive Time Stepping James Date CFX 3 October 17, 2005 23:15
Oscillation of adaptive time step--please help Sisiya Main CFD Forum 2 February 11, 2003 16:19
