November 8, 2018, 01:04 |
.cfx and .def file names not changing
Nick Thomas
Rep Power: 8 |
On my project I've changed the name of the different system cases I'm working on. However, when I go into my files (for example, ...dp0/CFX1/CFX) the cfx files (and .def if I choose to export) are still saving under the old name. Is there a way I can fix this?
November 8, 2018, 06:27 |
Rep Power: 144 |
You appear to be looking in the working directory of workbench. You have no direct control over what is done here as users are not intended to be using these files.
If you want direct control of the def and cfx files you should use CFX in stand-alone mode.
How to Write .def file from mesh file and ccl file? | evcelica | CFX | 11 | April 18, 2018 12:19 |
.DEF File Format | whumber | CFX | 2 | September 24, 2014 09:33 |
Hard drive storage and .cfx vs .def files | audrey | CFX | 5 | September 16, 2011 07:19 |
Creating geometry from .def file | az_f | ANSYS Meshing & Geometry | 1 | June 29, 2011 08:27 |
Write .def file from command line | Alejandro | CFX | 3 | September 11, 2005 19:14 |
