CFX-5.7.1 MPICH distr. parall. + user routines
Old   March 17, 2005, 05:41
Default CFX-5.7.1 MPICH distr. parall. + user routines
Claudia
Hi, I'm trying to start a run in mpich distributed parallel (windows) which includes a user subroutine and a junction box routine for particel injection. Everytime an error occures an look like this:
An error has occurred in subroutine ErrAction Unable to find library winnt/hollow_cone_distribution_HK.dll on path "c:/programme/Ansys Inc/CFX/shared/"
If i start the CFX-run in PVM-distributet parallel mode everything is right. But when i add a second computer with two more partitions the error occurs.
Thanks
Claudia
Old   March 18, 2005, 11:22
Default Re: CFX-5.7.1 MPICH distr. parall. + user routines
Jeff
Claudia,
It looks like some of the partitions can't find your user routine (assuming your routine is the hollow_cone_distribution_HK.dll in the message). Each partition (CPU/machine) has to be able to see the file. If you're storing it on C: drive of the master machine, then the other machines can't find it. You have two choices:
1. Copy the dll to the "exact" same location on every machine, or 2. Put the files on a network drive to which all machines have access through the same drive letter (i.e. T:/CFX/FORTRAN)
This should sort it out.
Jeff
Old   March 18, 2005, 12:39
Claudia
that's right. Thank you. I detected that i had to change something in the cfx5mkext.cll so that the user.dll could work with mpi. With all changes together it works.
Claudia
Particle User Source in ANSYS CFX Jun CFX 0 September 8, 2010 10:28
CFX User Conf Proceedings Available 94,96,97 Robert Main CFD Forum 0 August 7, 2005 12:54
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
CFD Short Course & CFX User Day Chris Reeves CFX 0 September 11, 2000 09:53
CFX User Subroutine Archive David Creech Main CFD Forum 0 March 17, 1999 13:41
