Cfx5solve error: Unable to retrieve mon from ...
Old   March 10, 2005, 06:02
Default Cfx5solve error: Unable to retrieve mon from ...
Forrest
Hi all,
I am using CFX5.7 to solve building ventilation problem. The solver stops quite often with the following messages (doesn't repeat, just randomly crashing).
An error has occurred in cfx5solve: The CFX-5 solver could not be started, or exited with return code 255: No results file has been created
An error has occurred in cfx5solve: Unable to retrieve mon from working directory: Cannot move to h:\workbench\dininghall\cfx5sim\dininghallsim1_001 \mon: Permission denied
Warning! An error has occurred during creation of a directory for additional output files. To avoid losing results, the working directory h:\workbench\dininghall\cfx5sim\dininghallsim1_001 .dir will be kept at the end of the run. Please tidy this directory up yourself when you have extracted what you need from it. The following user files have been saved in the directory h:\workbench\dininghall\cfx5sim\dininghallsim1_001 : mon
Anyone comes across this problem before? It wasn't disk space problem and it doesn't happen in other PCs within my working institute, just constantly happens on my machine. Thanks for your help very much.
Regards, Forrest
Old   March 10, 2005, 06:49
Default Re: Cfx5solve error: Unable to retrieve mon from .
wilson
hi i got this problem once when someone accidently shutdown the server computer. check out ur LAN connection or some how ur connection with server goes down.
Old   March 10, 2005, 06:56
Forrest
Thank you, wilson
This problem also happens when i am running on local drive. Not sure if this way can bypass the effect of the Server.
Regards, Forrest
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
An error has occurred in cfx5solve: yuan CFX 1 June 8, 2008 16:12
cfx5solve command line Steve Collie CFX 1 July 27, 2007 10:39
Error: Unable to retrieve mon from working directo Atit Koonsrisuk CFX 6 February 20, 2004 06:07
