Estimating Kolmogorov scale in LES
Old   October 29, 2018, 11:08
Default Estimating Kolmogorov scale in LES
Brian
gotang is on a distinguished road
Dear all,
I was hoping someone might be able to advise me on how best to estimate the Kolmogorov (length) scale in practical terms in CFX. I am running LES simulations using the WALE SGS, and am pretty new to running LES simulations at all.
So far, my best idea has been to follow the treatment from Pope's Turbulent Flows (section 13.3.3) which has:
\epsilon \approx P_r = - \tau_{ij}^r \overline{S_{ij}}
where:
\tau_{ij}^r \equiv \tau_{ij}^R - \frac{2}{3}k_r \delta_{ij}
\tau_{ij}^R \equiv \overline{U_i U_j} - \overline{U_i}\; \overline{U_j}
k_r \equiv \frac{1}{2} \tau_{ii}^R \equiv \frac{1}{2} (\overline{U_i U_i} - \overline{U_i}\;  \overline{U_i})
\overline{S_{ij}} \equiv \frac{1}{2}(\frac{\partial \overline{U_i}}{\partial x_j} + \frac{\partial \overline{U_j}}{\partial x_i})
allowing \epsilon to be calculated directly from the velocity/strain tensors (averaged appropriately and saved out as transient statistics), and then use \eta \equiv (\frac{\nu^3}{\epsilon})^{\frac{1}{4}} to estimate the Kolmogorov length scale.
This doesn't seem like a particularly direct method to me though; is there a better/faster way of doing it?
Thanks in advance!
gotang is offline   Reply With Quote
Old   October 29, 2018, 18:37
There are a whole bunch of ways to estimate epsilon, the Fluent manual lists a lot of them (http://jullio.pe.kr/fluent6.1/help/html/ug/node178.htm)
But note these estimates rely on knowledge of things like length scales, turbulent viscosity ratioes and so on, and these parameters can be difficult to determine as well. You will have to determine whether any of these approaches are going to work better than the direct (and more formally correct) method you describe.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   November 1, 2018, 07:44
Brian
Brilliant - thanks! I'll have a look and see if any of those methods seem reasonable.
kolmogorov, les, scales, turbulence
what length scale should be used when calculating kolmogorov scale of fountain flow? John-Lee Main CFD Forum 1 May 9, 2017 03:16
Kolmogorov scale .... LES LESer Main CFD Forum 6 July 3, 2015 07:01
Kolmogorov length scale in LES maphd Main CFD Forum 0 April 6, 2015 13:08
LES inlet length scale f.neilson Main CFD Forum 0 January 31, 2005 14:26
Length scale separation in LES Ray Main CFD Forum 1 June 7, 2002 09:50
