negative heat transfer coefficient
Old   February 25, 2005, 08:32
Default negative heat transfer coefficient
Sigrid Andreae
Regarding the computation with conjugate heat transfer I have got negative heat transfer coefficients.
Would it be possible for someone to explain to me what happened? Since the difference of temperature determines the heat flux ,therefore, the heat transfer coefficient should be positive.
The fluid is water at 353 Kelvin, the massflow is 3 kg/s, the boundary value at the outlet is 3bar. The mesh is very fine (y+>6) and I used the SST Model.
Regards and thanks, Sigrid Andreae
Old   February 26, 2005, 08:13
Default Re: negative heat transfer coefficient
Twiti
Considering your boundary conditions, I think maybe the result you got has not reach a convergency.
calculate heat transfer coefficient in repeated geometry mullenc525 CFX 4 January 24, 2017 15:30
BOILING HEAT TRANSFER COEFFICIENT John CFX 3 April 4, 2012 18:50
Distribution of surface heat transfer coefficient along the axial direcion of a tube andred FLUENT 0 November 16, 2010 22:13
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
