Multiple domains
Old   February 22, 2005, 14:41
Default Multiple domains
Andrew
Hello,all
In tutorial 15(Multiphase Flow in Mixing Vessel),the meshes of the two domains are in CFX-4 and CFX-5 Def/Res file formats respectively. When importing the impeller, the mesh was moved (transformed) to its correct position. I have two questions regarding this procedure:
1)How the distance of the tranformation was determined (in this tutorial, Dx: 0.275, Dy: 0, and Dz: 0)
2)How to generate the two domains via Workbench? Again, if I generate the mesh seperately(in two mesh files), how to determine the distance to move when importing mesh in CFX-pre?
If I generate the two domains togetheras two bodies (in one mesh file), how to mesh the two bodies seperately in CFX-mesh?
Thanks for your time and suggestions!
Andrew
Old   February 24, 2005, 13:59
Default Re: Multiple domains
Andrew
can someone give me some tips??please
Old   February 24, 2005, 17:41
Well, now that you asked so nicely....
Q1) The transformation distance is whatever is required to get the impeller and stator to properly match.
Q2) You can generate a mesh suitable for multi-domain models by either meshing each part seperately and importing the meshes seperately into CFX-Pre, or meshing it simultaneously. Have a look at a tutorial problem where they do a multi-domain mesh for how to do it.
Old   February 24, 2005, 21:04
Andrew
Thanks, Glenn. Very much appreciated.
For Q1), I understand that 'the transformation distance is whatever is required to get the impeller and stator to properly match', But I am not clear how that distance was determined in this tutorial. Does that comes from the the difference of reference coordinates when generate the two geometry(or mesh) files?
For Q2), 'You can generate a mesh suitable for multi-domain models by either meshing each part seperately and importing the meshes seperately into CFX-Pre'-----------with DM and CFX-mesh, can I build the two domains in one geometry file and generate different meshes for them? Or I must build the two domains in seperate geometry files and then meshing seperately?
Regards!
Andrew
Old   February 27, 2005, 17:40
Q2) Just after the section of my answer you quoted I said "or mesh it simultaneously". Yes, you can mesh multiple domains simultaneously. Do whatever is easiest for your geometry.
Old   March 1, 2005, 15:25
Andrew
Thanks again, Glenn. I tried several times and finally understood what you mean.
Best regards!
Andrew.
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Meshing Multiple Domains at Once ! rvallejo ANSYS Meshing & Geometry 1 June 19, 2010 22:49
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 16:20
Multiple domains - buoy. ref. temp. setting Forrest CFX 8 February 22, 2006 14:43
