L Fuchs
Rep Power: 7 ![]() |
i'm an Ansys newbie and need help. For my masterthesis i have to do a numerical Simulation for a given aerospike nozzle in diffrent altitudes. I have two inlets, the first one for the surrounding Air and the second one is the outlet opening of the combustion chamber ( the fuel is water or rather the steam). The other components are opening, outlet, aerospike(wall). So how can i handle two inlets with two diffrent materials? Do i have still one domain and what are the settings for the bounderies for the inlet of the aerospike. I have the required mass flow for the nozzle and the exact informations about the fuel ( evaporation degree, temperature, pressure). You can find a screenshot from my actually setup. Thanks for your help. Would be great and sorry for my bad english. Greetings Lucas |
Rep Power: 144 ![]() ![]() ![]() ![]() |
First of all - why not model this as 2D axisymmetric?
The two different materials are either a multicomponent or a multiphase model. If the fluids are air and steam then you only have a single phase so this is a multi component mixture.
L Fuchs
Cause my prof want it so. But ty for you try. |
We hear "my prof told me to do it that way" many times on the forum. Take it from me, that you should develop a complex model like this using the simplest geometry which is representative, and this is a 2D axisymmetric geometry. If you need 3D geometry to add some 3D features then you should do that later, after you have developed the basic numerical approach on a 2D model.
aerospike, ansys 18.1, cfx setup, nozzle analysis |
3 Stage axial compressor CFX Setup | knixxor | CFX | 9 | November 29, 2016 13:38 |
Solidification in Ansys CFX (12.0 ) | mauricio | CFX | 2 | August 11, 2015 09:06 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
I got code 1 error from ANSYS CFX | zlor1324 | CFX | 0 | March 11, 2014 19:22 |
Temperature transferring from CFX to ANSYS? | Se-Hee | CFX | 0 | November 28, 2006 05:56 |
