micro-combustor simulation using hydrogen/air
Old   February 11, 2005, 11:48
Default micro-combustor simulation using hydrogen/air
Tony
I am modeling combustion in a micro-combustor(2mm). In order to make it run, I injected premixed stoichiometric H2/air mixture @ T=300K. The initial pressure and temperature in the combustor are 1e5Pa and 1400K, respectively. Finite rate chemistry model is used and the forward reaction rate is specified as "Marinov one-step" mechenism(Marinov, Westbrook, and Pitz, 1995). Inlet H2/air mixture velocity is 50m/s and timestep is 1e-7 s. However, the results shows that it doesn't burn. I see H2/air mixture filled in the combustor and temperature is about 800K.
Since the dimension is very small, I do get a warning massage saying that the average Raynolds number is below 100, which is out of the range of the SST turbulence model.
Anybody knows why the combustion is not ignited? Thanks!
Old   February 14, 2005, 03:36
Default Re: micro-combustor simulation using hydrogen/air
Rob
Is the Marinov mechanism predefined in cfx-5 or did you define it by your own?
micro channel heat exchanger design serpil kaya Main CFD Forum 6 March 25, 2018 08:34
Macro and Micro pipe flow comparison Dave Main CFD Forum 0 December 13, 2007 15:04
Micro Fluid Richard Phoenics 6 March 4, 2002 09:46
Get a free or low price CFD or engineering estimate software about micro air vehicle. QingHua Zeng Main CFD Forum 3 May 16, 2000 12:04
CFD in micro fluidics? Ming-Jyh Chern Main CFD Forum 4 November 22, 1999 18:08
