modelling heat generation occourred by friction |
February 11, 2005, 06:29 |
Hi everybody, I'd like to know if it's posible in CFX to take acount of the heat generation that occours into a batch reactor beacuse of the frictional effects that take place between solid particles and the impeller / walls of the reactor / baffles. The fluid in this case is a dry powder and the particle size ranges between fraction of and few millimeters. The laboratory model is able to completely dry the 20 kg of the said fluid and then to rise the temperature well over 120°C in about 1 hour. I'd be really grateful if someone could post me a few lines and tell me about topics in CFX reference I could ask to my possible CFX vendor / assistant. Thank you a lot in advance, all replies are wellcome.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
heat transfer modelling of reciprocatingcompressor | Ramandeep singh | FLUENT | 2 | April 12, 2015 03:59 |
Modelling Heat Convection in a Rotating Disk | Rob Windram | FLUENT | 0 | February 27, 2009 06:09 |
Modelling heat transfer in wood | May | FLUENT | 0 | November 9, 2006 02:41 |
Heating of a solid cylinder with internal heat generation | Sriram Popuri | Main CFD Forum | 6 | July 13, 1999 18:09 |
