turbulence models constants
Old   January 26, 2005, 12:08
Default turbulence models constants
Aline Luz Salgado
Does anybody knows if it is possible to modify the turbulence models constants?
Old   February 3, 2005, 15:37
Default Re: turbulence models constants
Ian
Yes it is, but is pretty unadvisable. They are hidden expert parameters. If you beg and plead someone at CFX might tell them to you. But probably not.
Old   February 16, 2005, 02:08
dd.nvs
Hi It is possible directly with CFXPRE of CFX5.7. But also by expert parameter dd nvs
Old   March 1, 2005, 10:19
Joo Hie Yi
Turbulence k-epsilon model
Incompressible Turbulence models achinta OpenFOAM 4 May 27, 2010 11:35
Significance of constants in Std.-ke and Realizable-ke turbulence models mumtaz FLUENT 0 June 18, 2009 08:38
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 16:39
