CEL error in tutorial #20
Old   January 21, 2005, 15:30
Default CEL error in tutorial #20
Anurag
In tutorial 20, I am getting error while defining boundary condition 'ball". In "Mesh Motion" of boundary detail tab when "displacement y component" is set to dBallNew, it gave following errors
Bad expression value 'dBallNew' detected in parameter 'Displacement Y Component' in object '/FLOW/DOMAIN:checkValve/BOUNDARY:ball/BOUNDARY CONDITIONS/MESH MOTION'.
CEL error: Error in setting: "FFlow" via the expression: force_y()@Ball
force_y()@: read successfully, and then error found at item: Ball syntax error
Initially I created expressions individually. When it did not work i imported ValveFSI_expressions.ccl I got the same error in both cases. Has anyone got the same error? Please help me.
Anurag
Old   January 21, 2005, 17:23
Default Re: CEL error in tutorial #20
Rui
At the CEL expression, Ball indicates a boundary condition. So the boundary condition has to have exactly that name, Ball (it is case sensitive).
For what you wrote I would say that you named the boundary condition as ball (with small b), while in the CEL expression you have Ball (with a capital B).
There is a bug in CFX-5.7 related with the moving mesh capability (it was fixed in CFX-5.7.1). So if you are using CFX-5.7 and after you have managed to solve you problem, you get this error in CFX-Solver: "The CFX-5 solver could not be started, or exited with return code 255: No results file has been created", take a look at: http://www.cfd-online.com/Forum/cfx.cgi?read=9065 , and to http://www.cfd-online.com/Forum/cfx.cgi?read=9072 .
Good luck. Regards,
Rui
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 12:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 10:41
